Warning message
Cisco 3660 flash memory
Jul 29th, 2003
We are trying to delete a file from the flash memory of a c3660 running IOS 12.1(5)T:
IOS (tm) 3600 Software (C3660-IS56I-M), Version 12.1(5)T, RELEASE SOFTWARE (fc1).
With the command delete <file> we marked "deleted" the file:
System flash directory:
File Length Name/status
1 10682668 c3660-is-mz.121-5.T.bin [deleted]
2 11441980 c3660-is56i-mz.121-5.T.bin
3 468984 mica-modem-pw.2.7.2.0.bin
4 470849 mica-modem-pw.2.7.2.1.bin
5 476630 mica-modem-pw.2.7.4.0.bin
[23541436 bytes used, 10012996 available, 33554432 total]
32768K bytes of processor board System flash (Read/Write)
BUT we don't find the "squeeze" command to free the
space on the flash memory...
How can we permanently delete a single file on the
flash ?
Thank you, best regards.
Alessandro Asson
CINECA - Italy.
ashok_boin Tue, 07/29/2003 - 02:22
  • Bronze, 100 points or more
Is your IOS version is 12.1(15)? Try directly with "squeeze flash" command. Before that take backup of your active flash files to a TFTP server, after squeezing out, copy same files to flash.
Ashok.
cineca Tue, 07/29/2003 - 02:58
My version is 12.1(5)T and there is no squeeze
command at all ..
May be you intend trying with "erase flash" command ?
Thank you.
Bye, Alessandro Asson
