07-29-2003 06:27 AM - edited 02-20-2020 10:53 PM
I am trying to connect to the inside interface of our PIX 515e (v6.3.1) using putty ssh - and each time I try I am immediately refused with "Network error:connection refused". However I am able to connect fine using Tera Term Pro and it's ssh extension - so I would think all is properly set up on the PIX.
I have set putty to only use ssh v1 and left the other settings alone. I have tried to use the logging function of putty; but really get no useful info from it - nor from the PIX logs for that matter.
Can anyone offer any tips on making this work? I get the feeling I am missing a really simple step here somewhere.
Nick
07-29-2003 07:13 AM
what does the putty.log file say? Try turning on logging on the pix also (debug mode) and see if related entries appear.
What kind of encryption are you using for the SSH connection? Try putting 3DES on top followed by DES and see what happens (putty client -> connection -> SSH -> Encryption option).
Tom
07-29-2003 07:42 AM
Tom, the log file says nothing - other than to repeat the same "connection refused" message. When I review the logs on the PIX there is no mention of any attempt by the client to attach - which I find odd. Maybe this putty client is never actually trying to connect - it fails very quickly.
I have already placed 3DES at the top followed by DES - no luck.
I just now tested trying to use plain telnet to a router using putty.exe - even this fails to work. If I try that same connection with puttytel.exe it works fine.
Maybe my download of putty.exe is corrupt?
Nick
07-29-2003 07:51 AM
Well, I'm humbled - it ended up being my personal FW - no warning, no indicator, no prompt, no nothing - just blocked the traffic.
I should have checked this sooner; but it is new and I am still growing my dislike for it.
Thanks for responding,
Nick
11-02-2003 11:53 PM
Dear Nick ,
we both are on same track , even i fade up with that error trying to access PIX(VPN), I would highly appreciate if you provide any sort of assistance .. thanks
Azhar
11-03-2003 04:36 AM
Hi Azhar,
I'm afraid that after I found out it was the firewall causing the problem my investigation stopped. Surely the two products work in slightly different manners; but what specifically I don't know. Unfortunately, I never have time to track these little annoyances down to completion.
Nick
