Need to disable split tunneling from a VPN client connection.
Jul 29th, 2003
I am using pix firewall version 6.2 and VPN client configuration with VPN client software version 2. When I open the tunnel, the VPN client is able to communicate to the enterprise network but also at the same time can surf the internet. I need to disable split tunneling but in the VPN client software there´s no option to do so. Regarding documentation, I found there´s a method but for VPN client 3.5 software or earlier version and my PIX firewall configuration looks like that one used for VPN client version 1.1.
What can I do to disable split tunneling using the same software I have, I mean, only using configuration.
jackko Tue, 07/29/2003 - 14:57
  • Gold, 750 points or more
create another vpngroup; group1 enable split tunneling; group2 disable split tunneling
sguerrero Wed, 07/30/2003 - 15:09
It is not very clear for me your suggestion. . Here´s the configuration I have:
access-list 101 permit ip 10.0.0.0 255.255.255.0 172.16.1.0 255.255.255.0
ip local pool test 172.16.1.1-172.16.1.10
nat (inside) 0 access-list 101
crypto dynamic-map dynmap 15 set transform-set myset
crypto map mymap 5 ipsec-isakmp
crypto map mymap 5 set transform-set myset
crypto map mymap 15 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap interface outside
isakmp enable outside
isakmp key ***** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp client configuration address-pool local test outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 3600
What should I change here related to the group? I only have 1 group created and want to disable split tunneling for whomever in this group.
Thanks for any comment.
jmondaca Mon, 08/04/2003 - 07:45
You have to disable the split-tunnel in the vpngroup
Hope it Helps.
Jorge.
