Warning message
HSRP Troubleshooting
Jul 29th, 2003
I'm presently implementing HRSP btw 2 cat 6509 (each having 1-sepervisor engine with MSFC2) switches with inter-vlan routing btw 10 vlans. However, the hosts on the vlans get frozen when the primary switch fail-over to the second switch.
What do you think is reponsible and how could i resolve this problem?.
deilert Tue, 07/29/2003 - 08:56
  • Silver, 250 points or more
DO you have port fast enabled on the switch ports that are connected to the clients off the server ?
By enabling this the ports directly connected will not perform spanning tree calculation , the takes approx 40 seconds , You only want to configure this on ports attached to PC's or server , never ports attached to other switches or routers.
