Warning message
My FXO port is disconnection
Jul 30th, 2003
Hi, I have a 1700 (12.2(4)T3) with FXO ports and when I call the extension connected to it, first it gives tone, but after it disconnect. Any help ?
Thank you !
jtufail Wed, 07/30/2003 - 13:19
I am assuming your FXO port is connected to the jack for a line from PSTN? You call that line and the caller hear a tone and disconnects? Can you describe the topology and relevent config?
cweissheimer Thu, 07/31/2003 - 15:20
Thanks for your replay.
My FXO ports are connected to PABX directly in extension ports, so when I call these extension's numbers I should give me the tone. In my case, I got this tone, but suddenly, it stops and gives busy
tone.
Cleber
thusain Wed, 07/30/2003 - 16:05
  • Silver, 250 points or more
FXO port is supposed to give dialtone when it is called. You need to configure connection plar under the fxo port :
connection plar 1234
where 1234 is the number you want the call to go to.
Taimoor
