Warning message
VXworks to IOS conversion w/ WLSE
Jul 31st, 2003
I can convert one of my 1200 access points (firmware 12.02T) to IOS with the Wireless Lan Solution Engine (2.0) and configuration of AP is maintained. However, when I convert more than one AP at a time with WLSE, all APs are assigned the same IP address and hostname, causing problems. Has anyone experienced this in the upgrade process?
Thanks!
jakew Thu, 07/31/2003 - 13:42
  • Silver, 250 points or more
Are you attaching a configuration template for your security parameters? If so, what's in it? Do a "preview" to see if there's arbitrarily something in it that'll set the IP address.
mccormickk Fri, 08/01/2003 - 05:18
Thanks for the reply.
I have attached a security template, following the documentation. There is nothing regarding IP info in it. Also, I tried the upgrade on 2 separate groups, both groups acquired an IP & hostname of one AP in their respective groups. Is the WLSE only capable of one AP IOS upgrade per job?
jakew Sun, 08/03/2003 - 10:37
The conversion should support multiple APs per job. Haven't seen this myself. Need to get the test team to look into it.
yantisj Wed, 08/13/2003 - 15:50
We have the same exact problem. The only workaround at this time seems to be scheduling individual jobs for each AP. It sucks, but it saves a lot more time than dealing with the alternative. TAC doesn't seem to know and we're going to have to wait for a bug fix it seems.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
