sachinraja Fri, 08/01/2003 - 06:36
  • Red, 2250 points or more
ACS does not have inbuilt DHCP option. You can anyway enable the service on the server which runs ACS.
jeff.k Fri, 08/01/2003 - 08:00
Yes. It is not visible by default though. You must first go into Interface Configuration>>Advanced Options and choose IP Pools.
Then, when you go back to System Configuration, you will have the IP Pools option
Jeff
sachinraja Sat, 08/02/2003 - 03:50
Right.. but that is an additional installation that you have to do it on the server. ACS , by default does not have this option.
