Warning message
1200, 1100 or 350's for Office WLAN?
Aug 1st, 2003
We are working to install 3 floors worth of wireless in our office building, Which AP's would be the recomended ones? From what I take, the only differance between the three is upgradability. Is this correct?
derwin Sat, 08/02/2003 - 20:31
  • Cisco Employee,
If you want to run dual band then the 1200 is the one to get The 1200 can run either IOS or VxWorks
The AP1100 is very price effective and the radios can be field replaced if you want to change to 802.11g when it comes out but has fixed antenna Runs IOS only
The AP350 is the oldest model of the 3 and is a fixed configuration 802.11b radio that can not be hardware upgraded in the future (firmware updates are avaliable) but can be ordered with removeable antenna so you can use higher gain ones if need be
At this point in time it only runs VxWorks
The best one really depends on the size of network and what future expansion you expect
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
