HTTPS problems on concentrator 3005
Aug 3rd, 2003
Hi there,
we recently installed two vpn concentrators at seperate sites, with the same configurations (except for the obvious ip address changes...).
One concentrator accepts HTTPS connections fine, however the other one gives us an error on boot
13 08/01/2003 16:42:53.390 SEV=4 SSL/4 RPT=1
Unable to create SSL default context: bad certificate.
and then when we try to connect to it on HTTPS...
17 08/01/2003 16:43:33.230 SEV=4 SSL/2 RPT=1
Default context does not exist.
any ideas would be appreciated :)
thanks
daniel
rjphillips Mon, 08/04/2003 - 01:06
Try regenerating the certificate in the administration>Certificate management section.
