rjackson Mon, 08/04/2003 - 06:27
  • Bronze, 100 points or more
not sure about your question. Heres the answer on the disk vs slot issue
Flash memory cards use similar commands. The primary syntax change is that disk0: or disk1: refers to Flash memory ATA disks, while slot0: or slot1: refers to Flash memory cards. Generally, use the syntax slot0: for Flash memory cards less than 20 MB, and use disk0: for Flash disk greater than 20 MB. Keep in mind that there are 32 MB linear PCMCIA Flash cards where you use slot0.
And here's a good link on the subject
http://www.cisco.com/en/US/customer/products/hw/routers/ps341/products_tech_note09186a00800a7515.shtml
