Warning message
AS5300--E1 R2 country code
Aug 5th, 2003
Hi All,
What should I use in the following command as my country is not listed in the country code list.
5300(config-ctrl-cas)#country <country> use-default
Thanks in advance,
Richard
ivillegas Tue, 08/12/2003 - 08:37
  • Silver, 250 points or more
Try to find the standard used by your country for E1R2 signalling and configure that in your configuration
The mica modem needs a country code specified as well,
modem country mica
If the standard is different specify the applicable modem.
In case this doesn't help you need to specify your country settings under cas-custom sentence,
5300(config-controller)#cas-custom 0
5300(config-ctrl-cas)#?
CAS custom commands:
Also use the following debug commands
debug isdn q931
debug cas
debug modem
debug modem csm
debug vtsp all
gomesrichard Sun, 08/17/2003 - 20:45
Thanks, ivillage! I am new to this E1 thing, but it would be great to configure as5400.
Thanks and best regards
Richard
