6509 and Power Supplies
Aug 6th, 2003
We have a 6509 with a 1300w redundant power supply connected to 110V. If our 6509 is Fully populated will one PS be able to keep it up and running or do we need 220v.
jmaines Thu, 08/07/2003 - 04:18
Gaban,
This depends on the type of modules you have installed in the 6509. Total power available for the 1300W power supply is 27.46 amps. Add the amount of power consumption for the modules you have installed currently and subtract it from the 27.46. This will tell you if you need to upgrade the power supply. You can find information at the following link: http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007f9a2.html#46335
Hope this helps.
Josh
