ADSchemaSetup
Aug 7th, 2003
Unity 4.0.2
I try to run ADSchemaSetup and I get the following error message:
'Setup failed to initialize Active Directory
Please verify the following:
1)That your network connection is active
2)That active directory services is running
3)That you are logged onto the schema master
4)That you are a member of the Schema Admins security group '
All these conditions are true on my system but I still get this error message.
Any ideas??
joconnors Fri, 08/08/2003 - 05:38
Check to see if the Remote Registry service is running on both the server you're trying to run the update from and the Schema Master (if they're not one in the same).
