Warning message
IDS Security Monitor no Events in viewer
Aug 8th, 2003
When I look in my event viewer, nothing is there. The devices were discovered. It's a new install of IDS4.0 and ciscoworks2000. I've got a 4220-E and a 4210 that both show up in the devices tab in Security Monitor. If I select "monitor", "events", then "Launch Event Viewer" with "At Earliest" and "Don't Stop" selected, it comes up empty. I know that one of the devices is working because it's updating the ACL on the router. any help would be appreciated!
John
hadbou Thu, 08/14/2003 - 07:54
  • Bronze, 100 points or more
Try restarting the event viewer, also check the bug tool kit for any known bugs.
wkho Thu, 08/14/2003 - 10:02
Did you setup a VACL or SPAN?
