Warning message
Disabling read receipts
Aug 11th, 2003
Apparently there is a registry hack that hides read receipts from Unity so Unity does not recognize them as messages. Anybody knows where this is done??
n.kyei Mon, 08/11/2003 - 07:43
I think I found it, it was under Tools Depot => Administration Tools, select 'Exclude return receipts from voice mail stack'. This should be set to 1.
lindborg Mon, 08/11/2003 - 07:59
  • Cisco Employee,
yeah, that's the one.
Just to be clear, this affect only read and delivery receipts - Non delivery receipts will always be presented. In 4.0(1) and later you can dictate that these NDRs be offered at the "bottom" of the message stack but they'll always be there.
trosamilia Tue, 09/30/2003 - 12:31
I am dealing with the exact same issue. I am not sure exactly where you are finding this information. Can you please be more specific, on the location of the 'Exclude return receipts from voice mail stack'.
lindborg Tue, 09/30/2003 - 13:46
  • Cisco Employee,
You didn't note your version of Unity but if you're running 4.0(3) or later you should see the "advanced settings tool" in the Tools Depot application right off your desktop. You can get an updated version of the Advanced Settings Tool off www.CiscoUnityTools.com, however that option for excluding return reciepts has been in there for some time.
fmarotta Mon, 12/22/2003 - 08:12
I am running unity 4.0.3 with domino 6.0.2. I have set the option in the advanced settings tool for "exclude return reciept from voicemail stack" to 1 and restarted unity. However when I get a RR in my inbox unity is still reading it to me. I even disabled the AVTTSSVR service.
Has anyone seens this problem before?
Frank
