I know you can block Java and Active X with a PIX but are there product available that will do this intelligently rather than a full block? Maybe another vendor if not in Ciscos portfolio
Also as the PIX can block java and active-x on port 80 is there any other types of mobile code I need to be aware of?
Products from WebSense and N2H2 filter out specific URL's in conjunction with the PIX, not sure if they can be set up to filter out just Java and ActiveX, I don't believe they can but may be wrong on that.
Java and ActiveX are the only ones you can filter within the PIX. They're certainly the most dangerous from a hacker's point of view. ActiveX filtering merely comments out everything between the
