Line Protocol on 1601 up and down
Aug 12th, 2003
I am having a problem with a 1601 Router. The line protocol goes up and down. I installed another WIC 1T to test if the problem was on the Existing WIC but still have the same problem with the new one.
The IOS version running is 12.0 (3)T . Also when i use another Router on the same Link, it works fine, this means the link is ok, the problem must be with the router.
Anyone knows any known problems with 1601s with IOS 12.0 (3) T ? Help highly appreciated
regards
KM
mtnuga Tue, 08/12/2003 - 03:01
Both router have the same version
IOS (tm) 1600 Software (C1600-Y-M), Version 12.0(12), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 10-Jul-00 19:59 by htseng
Image text-base: 0x02005000, data-base: 0x0245E484
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ROM: 1600 Software (C1600-RBOOT-R), Version 12.0(3)T, RELEASE SOFTWARE (fc1)
MTNTEST1 uptime is 17 hours, 39 minutes
System restarted by power-on
System image file is "flash:c1600-y-mz.120-12"
cisco 1601 (68360) processor (revision C) with 6144K/2048K bytes of memory.
Processor board ID 24815082, with hardware revision 00000005
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
System/IO memory with parity disabled
8192K bytes of DRAM onboard
System running from RAM
7K bytes of non-volatile configuration memory.
4096K bytes of processor board PCMCIA flash (Read/Write)
KM
deilert Wed, 08/13/2003 - 06:29
  • Silver, 250 points or more
can you paste in your config
net-guru Wed, 08/13/2003 - 06:39
What does the debug int serial0/0 output show?
Make sure if you're logged in through telent you use the term mon command and enable console logging.
conf t
console logging
ctrl+z
term mon
debug int serial 0/0
