Warning message
Can IOS NAT (PAT really) inside clients to outside I/F address like a PIX?
Answered Question
Aug 13th, 2003
Is it possible to have a router do Port Address Translation and map all connections that come from the inside to the IP address assigned to the outside interface of the router like a PIX can? Not a pool, or seperate address, but use the actual address of the outside interface as the address that all the internal (outbound) connections get translated to?
I have not been able to find an example on this using IOS yet.
Correct Answer by mark-obrien about 14 years 1 week ago
Yes you can. Use the command "ip nat inside source list x interface y" command. Here is the link to it.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipras_r/1rfipadr.htm#1060550
Overall Rating: 5 (1 ratings)
