Unity 4.0.2 default failsafe message
Aug 14th, 2003
On a new installation if call manager 3.3.2 and unity 4.0.2 integrated into exchange 2000. When dialling the extension and getting unity greeting the server then replies "Sorry the the system is temporarily unable to complete your call please try again later".
When the user dials unity the same message is played after the password is entered.
All permissions check successful in the wizard and new users can be added into exchange from the system admin page.
Overall Rating: 3 (1 ratings)
kechambe Thu, 08/14/2003 - 08:07
  • Gold, 750 points or more
Are these machines patched for the Blaster worm? These symptoms you describer are consistent with infected systems. Please check out this URL:
http://www.cisco.com/warp/public/788/AVVID/unity-love-worm.html
Let me know if you are not infected and we can take it from there. Posting the exact even log messages would be helpful.
Keith
garry.connolly@... Thu, 08/14/2003 - 09:07
Keith,
We have run the appropriate file, and the server is not infected.
Here's an event :
Event Type: Error
Event Source: CiscoUnity_PHGreeting
Event Category: Error
Event ID: 107
Date: 14/08/2003
Time: 05:52:36
User: N/A
Computer: UMNHSDEW01
Description:
RecordMessage returned [0x80004005] on line 3269 of file e:\views\Unity4.0.1.55\un_Conv2\AvConvPhoneHandler\AvConvPHGreetingSvr\AvSPlayGreeting.cpp
Hope this sheds some light
Many thanks
ross.parker Tue, 09/02/2003 - 15:37
I am getting the same behavior and message.
lindborg Wed, 09/03/2003 - 07:00
  • Cisco Employee,
That error indicates a problem during a recording session - which seems odd based on the first description (i.e. you get that error without even hearing the greeting of the call handler) - I'm not sure that makes sense.
Are there any _other_ errors in the event log? Maybe something from the MIU component? What about if you dial in to check messages directly, do you get failsafe? If so, what error pops up there? Are _any_ calls working here?
I'm assuming you're on the same version as the original poster - if not, let us know what Unity build/CM and TSP versions you're using.
