Warning message
IPsec tunnel problems between Cisco router and WatchGuard Firebox
I have a problem to establish a VPN connection between these two boxes. As a Cisco I use a 1721 router with the c1700-k8sy7-mz.122-15.T5.bin IOS.
A tunnel can be established only from Cisco box to WatchGuard Firebox. When Watchguard tries to establish a VPN connection, I get an error message on the Cisco
Aug 7 10:20:22.175: IPSEC(validate_proposal_request): proposal part #1,
(key eng. msg.) INBOUND local= 195.91.44.100, remote= 62.217.33.200,
local_proxy= 192.168.199.0/255.255.255.0/0/0 (type=4),
remote_proxy= 172.26.90.0/255.255.255.0/0/0 (type=4),
protocol= ESP, transform= esp-des esp-sha-hmac ,
lifedur= 0s and 0kb,
spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x2
Aug 7 10:20:22.175: IPSEC(kei_proxy): head = sycon, map->ivrf = , kei->ivrf =
Aug 7 10:20:22.175: IPSEC(validate_transform_proposal): invalid transform proposal flags -- 0x2
I have checked the transform-set settings on both devices and they were the same. Then I have changed the transorm-set from
crypto ipsec transform-set sycon-set esp-des esp-sha-hmac
to
crypto ipsec transform-set sycon-set esp-des esp-md5-hmac
but got the same error message.
The configuration on the router is simple
crypto isakmp policy 1
hash md5
authentication pre-share
crypto isakmp key xxxxxxx address xx.xxx.33.200
crypto map sycon local-address Loopback0
crypto map sycon 1 ipsec-isakmp
set peer 62.217.33.200
set security-association lifetime kilobytes 8192
set security-association lifetime seconds 86400
set transform-set sycon-set
set pfs group1
match address 110
interface Serial1.1 point-to-point
ip address xx.xx.44.106 255.255.255.252
frame-relay interface-dlci 16
crypto map sycon
access-list 110 permit ip xxx.xxxx.199.0 0.0.0.255 xxxx.26.90.0 0.0.0.255
If there is a problem with the transform-set, can someone explain me what are flags in "invalid transform proposal flags -- 0x2 " error message and their meaning?
I was in the belief, that when there is a problem with a tranform-set, I will get error message like this
IPSec (validate_proposal): transform proposal
(port 3, trans 2, hmac_alg 2) not supported
Thank you.
Peter
