Warning message
Using hardware client 3002 to concentrator 3005
Aug 19th, 2003
I'm using the Hardware client 3002 to connect to a cisco 3005. The tunnel works fine and i have configured it to automaticly establish the tunnel as soon as the 3002 starts.
Now to my problem, i'm running windows NT as PDC and i want to join the domain using the vpn tunnel but it's just wont work.
However i can map everyting on the network, even get out on internet through the tunnel but join the domain doesn't work.
help me plz ;)
owillins Mon, 08/25/2003 - 07:16
  • Silver, 250 points or more
The VPN 3k cannot join directly, but the client can always join the domain. Its one of the options chosen on client side whether or not to log into the domain. In Indows NT, you MUST log into a domain - it can be the tunneled domain if the start before login option is set.
aramix Tue, 08/26/2003 - 03:35
i'm not using the software client.....using hardware
