PIX 501 Firewall Configuration
Aug 19th, 2003
I am trying to add this firewall to our existing network. I want to disable the dhcp server on the inside interface and set a different private IP address than the default 192.168.1.1. When I use the configuration listed below, the connected devices are not getting the correct IP address from our existing DHCP server. What am I doing wrong?
PIX Version 6.3(1)e 0:05:00
interface ethernet0 auto 1:00:00 half-closed 0:1
interface ethernet1 100full h225 1:00:00ion 6.3(1)i
nameif ethernet0
outside security0
enable password xxx encrypted
passwd xxx encrypted
hostname pixfirewall
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 30
mtu outside 1500
mtu inside 1500
ip address outside ISP-STATIC-ADDRESS ISP-SUBNET-MASK
ip address inside PRIVATE-STATIC-ADDRESS SUBNET-MASK
ip audit info action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http PRIVATE-STATIC-ADDRESS SUBNET-MASK inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
terminal width 100
Cryptochecksum:xxxx
