Warning message
VOIP Configuration between FXO and FXS
Aug 20th, 2003
Dear Sir,
We have implemented Voice over IP on our IPLC circuit between foreign office and India office.
Topology is such that our foreign office is having 1700 series router with wan card
(Wic-1T) and one two port FXO card connected to PBX for PSTN and local connsctivity.
India end we have a cisco 1700 router with wan card (Wic-1T) and two port FXS card.
Also we have many other branches connected to India office router on point to point lease links running data and analog voice (FXS).
We have configured voip using PLAR feature between foreign office FXO and india office FXS card.
1) Currently India office users via IPLC can communicate over voice and data with the foreign office (FXS to FXO).
2) Foreign office users can communicate with the india office users connected to IPLC link (FXO to FXS)
3) India office users can communicate voip with other branches in india (FXS to FXS)
We want to configure the foreign office router in such a way that foreign users are able to talk to remaining branches in india office (FXO to Many FXS cards)
Will putting voice route in the foreign office solve the purpose or we need to change the router voice config from PLAR mode to some other mode.
How the foreign office PBX will differentiate between point to point voice calls and other location voice calls.
Will the PBX/Router in foreign office be able to give dial tone to the FXO card.
Can we use the india end router as a voice switch for routing voice calls between foreign office and all the branches in india.
Any suggestions/config will be appreciated
jtufail Wed, 08/20/2003 - 07:55
If I understand correctly you have FXO port in your foreign office with connection plar so any call coming in goes directly to your india office. Assuming you can ping to all other office branches in india from the foreign office, all you have to do it to take out the plar command and set dialplans for different sites. When a call would come in on the FXO, the caller will hear one short ringback and then a dialtone which is coming from the FXO when it goes off hook. After that user can dial the number say 1234 to go to one site 5678 to go to another site etc.
I hope that helps.
fmatrine Thu, 08/21/2003 - 03:35
Dear Sir,
Will the below config work or can i get a sample config for the my scenario
India Router :-
dial-peer voice 34 pots
destination-pattern 34
port 1/0
dial-peer voice 35 pots
destination-pattern 35
port 1/1
dial-peer voice 36 pots
destination-pattern 36
port 2/0
dial-peer voice 37 pots
destination-pattern 37
port 2/1
dial-peer voice 3400 voip (for calling Foreign office local extension)
destination-pattern +8...
session target ipv4:150.100.1.2
dial-peer voice 3400 voip (for calling PSTN line outside foreign office)
destination-pattern +9...
Foreign Office Router :-
dial-peer voice 3400 pots (for Local Calls)
port 1/0
dial-peer voice 3400 pots (for PSTN Calls)
port 1/0
dial-peer voice 3500 pots (for LOCAL Calls)
Prefernce 1
port 1/1
dial-peer voice 3500 pots (for PSTN Calls)
port 1/1
dial-peer voice 3600 pots (for Local Calls)
preference 2
port 2/0
dial-peer voice 3600 pots (for PSTN Calls)
port 2/0
dial-peer voice 3700 pots (for Local Calls)
preference 3
port 2/1
dial-peer voice 3700 pots (for PSTN Calls)
port 2/1
dial-peer voice 34 voip
session target ipv4:150.100.1.1
dial-peer voice 35 voip
dial-peer voice 36 voip
dial-peer voice 37 voip
jtufail Thu, 08/21/2003 - 08:14
The configs that you have pasted are for calls between the two sites only and they should work fine.
In the US the you are sending only 3 digits to the PSTN. Is this what you want to do? If you have to send variable digits you can use 9T instead of 9...
fmatrine Sun, 08/24/2003 - 21:30
Thanks for Prompt reply,
Will the below config will work for one to many locations.
India Office Router :-
dial-peer voice 2291 pots
destination-pattern 2291
port 1/0
dial-peer voice 2292 pots
destination-pattern 2292
port 1/1
dial-peer voice 2293 pots
destination-pattern 2293
port 2/0
dial-peer voice 2294 pots
destination-pattern 2294
port 2/1
dial-peer voice 30 voip
destination-pattern 30
dial-peer voice 110 voip
destination-pattern 110.
session target ipv4:129.25.0.1
dial-peer voice 200 voip
destination-pattern 200.
session target ipv4:129.55.0.1
dial-peer voice 201 voip
destination-pattern 201.
session target ipv4:129.50.0.1
dial-peer voice 220 voip
destination-pattern 220.
session target ipv4:160.0.0.1
dial-peer voice 221 voip
destination-pattern 221.
session target ipv4:160.0.0.2
dial-peer voice 222 voip
destination-pattern 222.
session target ipv4:129.1.0.1
dial-peer voice 223 voip
destination-pattern 223.
session target ipv4:129.5.0.1
dial-peer voice 224 voip
destination-pattern 224.
session target ipv4:129.4.0.1
dial-peer voice 225 voip
destination-pattern 225.
session target ipv4:129.3.0.1
dial-peer voice 226 voip
destination-pattern 226.
session target ipv4:129.2.0.1
dial-peer voice 227 voip
destination-pattern 227.
session target ipv4:129.8.0.1
dial-peer voice 228 voip
destination-pattern 228.
session target ipv4:129.9.0.1
dial-peer voice 330 voip
destination-pattern 330.
session target ipv4:129.20.0.1
dial-peer voice 400 voip
destination-pattern 400.
session target ipv4:129.30.0.1
dial-peer voice 440 voip
destination-pattern 440.
session target ipv4:129.40.0.1
dial-peer voice 441 voip
destination-pattern 441.
session target ipv4:129.65.0.1
dial-peer voice 790 voip
destination-pattern 790.
session target ipv4:129.11.0.1
dial-peer voice 800 voip
destination-pattern 800.
session target ipv4:129.15.0.1
dial-peer voice 1 pots
port 1/0
dial-peer voice 2 pots
Prefernce 1
port 1/1
dial-peer voice 3 pots
preference 2
port 2/0
dial-peer voice 4 pots
preference 3
port 2/1
dial-peer voice 229 voip
destination-pattern 229.
Pls confirm.
If possible can i get sample config for my scenarion
