Warning message
c3640 / could not add Pots dial peer
Answered Question
Aug 20th, 2003
this router running 12.1(3a)X16 having problems while adding potd dial peer. initially it had 6 pots peer but when wanted add 3 more pots peer it did the following
router(config)#dial-peer voice 720 pots
ERROR: could not add peer
Tried removing three pots peer but now its not allowing to add anymore Pots peer. 'sh tech' looks Ok and there is no memory leak
Could soemone shed some light on this
---------------- show version ------------------
IOS (tm) 3600 Software (C3640-IS-M), Version 12.1(3a)XI6, EARLY DEPLOYMENT
RELEASE SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sat 24-Mar-01 04:30 by shawnk
Image text-base: 0x60008950, data-base: 0x6105C000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
ROM: 3600 Software (C3640-IS-M), Version 12.1(3a)XI6, EARLY DEPLOYMENT
VVUK01 uptime is 3 weeks, 4 hours, 35 minutes
System restarted at 10:59:06 BST Wed Jul 30 2003
System image file is "slot0:c3640-is-mz.121-3a.xi6.bin"
cisco 3640 (R4700) processor (revision 0x00) with 43008K/6144K bytes of
memory.
Processor board ID 17883351
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
63 Serial network interface(s)
2 Channelized E1/PRI port(s)
4 Voice E & M interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board PCMCIA Slot0 flash (Read/Write)
Correct Answer by thusain about 14 years 23 hours ago
You are definitely having an issue with memory. Please include show mem sum show proc meme and show dial-peer voice sum.
Overall Rating: 5 (1 ratings)
Correct Answer
thusain Sun, 08/24/2003 - 11:40
  • Silver, 250 points or more
a.pawar Tue, 08/26/2003 - 01:10
It was a memory issue. Router was reporting it needs more memory. Is there a tool to calculate how much memory is needed for a no of dial peers?
