PIX 515 NAT/PcAnywhere help
Aug 21st, 2003
I'm in the process of writing a config for our PIX 515 that will allow telecommuters to work from home using PcAnywhere. We had a previous config on our router that did what we needed, but now that I'm putting a PIX in between the router and the internal network, I am kind of stumped. I'll reply to this post with the PIX config since this is too long. Here is the NAT portion of our current router config that has been working for years:
interface Ethernet0/0
ip address 216.x.x.x 255.255.255.224
ip nat outside
interface Serial0/0
interface Ethernet1/0
ip address 10.0.0.1 255.0.0.0
ip nat inside
ip nat pool HCDM 216.x.x.x 216.x.x.x netmask 255.255.255.224
ip nat inside source list 101 interface Ethernet0/0 overload
ip nat inside source static 10.0.0.2 216.x.x.x
ip nat inside source static 10.0.0.5 216.x.x.x
ip nat inside source static 10.0.0.7 216.x.x.x
ip nat inside source static 10.0.0.8 216.x.x.x
ip nat inside source static 10.0.0.10 216.x.x.x
ip nat inside source static 10.0.0.9 216.x.x.x
ip nat inside source static 10.0.0.11 216.x.x.x
ip nat inside source static 10.0.0.12 216.x.x.x
ip nat inside source static 10.0.0.13 216.x.x.x
ip nat inside source static 10.0.0.14 216.x.x.x
ip nat inside source static tcp 10.0.0.30 5631 216.x.x.90 5030 extendable
ip nat inside source static tcp 10.0.0.31 5631 216.x.x.90 5032 extendable
ip nat inside source static tcp 10.0.0.32 5631 216.x.x.90 5034 extendable
ip nat inside source static tcp 10.0.0.33 5631 216.x.x.90 5036 extendable
ip nat inside source static tcp 10.0.0.34 5631 216.x.x.90 5038 extendable
ip nat inside source static tcp 10.0.0.35 5631 216.x.x.90 5040 extendable
ip nat inside source static tcp 10.0.0.36 5631 216.x.x.90 5042 extendable
ip nat inside source static tcp 10.0.0.37 5631 216.x.x.90 5044 extendable
ip nat inside source static tcp 10.0.0.38 5631 216.x.x.90 5046 extendable
ip nat inside source static tcp 10.0.0.39 5631 216.x.x.90 5048 extendable
ip nat inside source static tcp 10.0.0.40 5631 216.x.x.90 5050 extendable
ip nat inside source static tcp 10.0.0.41 5631 216.x.x.90 5052 extendable
ip nat inside source static tcp 10.0.0.42 5631 216.x.x.90 5054 extendable
ip nat inside source static tcp 10.0.0.43 5631 216.x.x.90 5056 extendable
ip nat inside source static tcp 10.0.0.44 5631 216.x.x.90 5058 extendable
ip nat inside source static tcp 10.0.0.45 5631 216.x.x.90 5060 extendable
ip nat inside source static tcp 10.0.0.46 5631 216.x.x.90 5062 extendable
ip nat inside source static tcp 10.0.0.47 5631 216.x.x.90 5064 extendable
ip nat inside source static tcp 10.0.0.48 5631 216.x.x.90 5066 extendable
ip nat inside source static tcp 10.0.0.49 5631 216.x.x.90 5068 extendable
ip nat inside source static tcp 10.0.0.50 5631 216.x.x.90 5070 extendable
ip nat inside source static tcp 10.0.0.51 5631 216.x.x.90 5072 extendable
ip nat inside source static tcp 10.0.0.52 5631 216.x.x.90 5074 extendable
ip nat inside source static tcp 10.0.0.53 5631 216.x.x.90 5076 extendable
ip nat inside source static tcp 10.0.0.54 5631 216.x.x.90 5078 extendable
ip nat inside source static tcp 10.0.0.55 5631 216.x.x.90 5080 extendable
ip nat inside source static udp 10.0.0.30 5632 216.x.x.90 5031 extendable
ip nat inside source static udp 10.0.0.31 5632 216.x.x.90 5033 extendable
ip nat inside source static udp 10.0.0.32 5632 216.x.x.90 5035 extendable
ip nat inside source static udp 10.0.0.33 5632 216.x.x.90 5037 extendable
ip nat inside source static udp 10.0.0.34 5632 216.x.x.90 5039 extendable
ip nat inside source static udp 10.0.0.35 5632 216.x.x.90 5041 extendable
ip nat inside source static udp 10.0.0.36 5632 216.x.x.90 5043 extendable
ip nat inside source static udp 10.0.0.37 5632 216.x.x.90 5045 extendable
ip nat inside source static udp 10.0.0.38 5632 216.x.x.90 5047 extendable
ip nat inside source static udp 10.0.0.39 5632 216.x.x.90 5049 extendable
ip nat inside source static udp 10.0.0.40 5632 216.x.x.90 5051 extendable
ip nat inside source static udp 10.0.0.41 5632 216.x.x.90 5053 extendable
ip nat inside source static udp 10.0.0.42 5632 216.x.x.90 5055 extendable
ip nat inside source static udp 10.0.0.43 5632 216.x.x.90 5057 extendable
ip nat inside source static udp 10.0.0.44 5632 216.x.x.90 5059 extendable
ip nat inside source static udp 10.0.0.45 5632 216.x.x.90 5061 extendable
ip nat inside source static udp 10.0.0.46 5632 216.x.x.90 5063 extendable
ip nat inside source static udp 10.0.0.47 5632 216.x.x.90 5065 extendable
ip nat inside source static udp 10.0.0.48 5632 216.x.x.90 5067 extendable
ip nat inside source static udp 10.0.0.49 5632 216.x.x.90 5069 extendable
ip nat inside source static udp 10.0.0.50 5632 216.x.x.90 5071 extendable
ip nat inside source static udp 10.0.0.51 5632 216.x.x.90 5073 extendable
ip nat inside source static udp 10.0.0.52 5632 216.x.x.90 5075 extendable
ip nat inside source static udp 10.0.0.53 5632 216.x.x.90 5077 extendable
ip nat inside source static udp 10.0.0.54 5632 216.x.x.90 5079 extendable
ip nat inside source static udp 10.0.0.55 5632 216.x.x.90 5081 extendable
ip nat inside source static 10.0.0.3 216.x.x.x
ip nat inside source static 10.0.0.4 216.x.x.x
ip nat inside source static tcp 10.0.0.56 5631 216.x.x.91 5030 extendable
ip nat inside source static tcp 10.0.0.57 5631 216.x.x.91 5032 extendable
ip nat inside source static tcp 10.0.0.58 5631 216.x.x.91 5034 extendable
ip nat inside source static tcp 10.0.0.59 5631 216.x.x.91 5036 extendable
ip nat inside source static tcp 10.0.0.60 5631 216.x.x.91 5038 extendable
ip nat inside source static tcp 10.0.0.61 5631 216.x.x.91 5040 extendable
ip nat inside source static tcp 10.0.0.62 5631 216.x.x.91 5042 extendable
ip nat inside source static tcp 10.0.0.63 5631 216.x.x.91 5044 extendable
ip nat inside source static tcp 10.0.0.64 5631 216.x.x.91 5046 extendable
ip nat inside source static tcp 10.0.0.65 5631 216.x.x.91 5048 extendable
ip nat inside source static tcp 10.0.0.66 5631 216.x.x.91 5050 extendable
ip nat inside source static tcp 10.0.0.67 5631 216.x.x.91 5052 extendable
ip nat inside source static tcp 10.0.0.68 5631 216.x.x.91 5054 extendable
ip nat inside source static tcp 10.0.0.69 5631 216.x.x.91 5056 extendable
ip nat inside source static tcp 10.0.0.70 5631 216.x.x.91 5058 extendable
ip nat inside source static tcp 10.0.0.71 5631 216.x.x.91 5060 extendable
ip nat inside source static tcp 10.0.0.72 5631 216.x.x.91 5062 extendable
ip nat inside source static tcp 10.0.0.73 5631 216.x.x.91 5064 extendable
ip nat inside source static tcp 10.0.0.74 5631 216.x.x.91 5066 extendable
ip nat inside source static tcp 10.0.0.75 5631 216.x.x.91 5068 extendable
ip nat inside source static tcp 10.0.0.76 5631 216.x.x.91 5070 extendable
ip nat inside source static tcp 10.0.0.77 5631 216.x.x.91 5072 extendable
ip nat inside source static tcp 10.0.0.78 5631 216.x.x.91 5074 extendable
ip nat inside source static tcp 10.0.0.79 5631 216.x.x.91 5076 extendable
ip nat inside source static udp 10.0.0.56 5632 216.x.x.91 5031 extendable
ip nat inside source static udp 10.0.0.57 5632 216.x.x.91 5033 extendable
ip nat inside source static udp 10.0.0.58 5632 216.x.x.91 5035 extendable
ip nat inside source static udp 10.0.0.59 5632 216.x.x.91 5037 extendable
ip nat inside source static udp 10.0.0.60 5632 216.x.x.91 5039 extendable
ip nat inside source static udp 10.0.0.61 5632 216.x.x.91 5041 extendable
ip nat inside source static udp 10.0.0.62 5632 216.x.x.91 5043 extendable
ip nat inside source static udp 10.0.0.63 5632 216.x.x.91 5045 extendable
ip nat inside source static udp 10.0.0.64 5632 216.x.x.91 5047 extendable
ip nat inside source static udp 10.0.0.65 5632 216.x.x.91 5049 extendable
ip nat inside source static udp 10.0.0.66 5632 216.x.x.91 5051 extendable
ip nat inside source static udp 10.0.0.67 5632 216.x.x.91 5053 extendable
ip nat inside source static udp 10.0.0.68 5632 216.x.x.91 5055 extendable
ip nat inside source static udp 10.0.0.69 5632 216.x.x.91 5057 extendable
ip nat inside source static udp 10.0.0.70 5632 216.x.x.91 5059 extendable
ip nat inside source static udp 10.0.0.71 5632 216.x.x.91 5061 extendable
ip nat inside source static udp 10.0.0.72 5632 216.x.x.91 5063 extendable
ip nat inside source static udp 10.0.0.73 5632 216.x.x.91 5065 extendable
ip nat inside source static udp 10.0.0.74 5632 216.x.x.91 5067 extendable
ip nat inside source static udp 10.0.0.75 5632 216.x.x.91 5069 extendable
ip nat inside source static udp 10.0.0.76 5632 216.x.x.91 5071 extendable
ip nat inside source static udp 10.0.0.77 5632 216.x.x.91 5073 extendable
ip nat inside source static udp 10.0.0.78 5632 216.x.x.91 5075 extendable
ip nat inside source static udp 10.0.0.79 5632 216.x.x.91 5077 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 216.x.x.x
abruso Thu, 08/21/2003 - 09:07
Here is the PIX config I am working on. Not sure how to get NAT to work with PcANywhere like it does in the router. Will it work how it is set up now?
PIX Version 6.3(1)
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 100full
interface ethernet3 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 DMZ security50
enable password
hostname xxx
domain-name xxx.xxx
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list outside_access_in permit icmp any any echo-reply
access-list outside_access_in permit tcp any host 216.x.x.93 eq www
access-list outside_access_in permit tcp host 216.x.x.82 host 216.x.x.93 eq smtp
access-list outside_access_in permit tcp any host 216.x.x.92 eq syslog
access-list outside_access_in permit tcp any host 216.x.x.93 eq 443
pager lines 24
logging on
logging timestamp
logging monitor debugging
logging buffered errors
logging trap debugging
logging history errors
logging host dmz 192.168.0.5
mtu outside 1500
mtu inside 1500
mtu Corp-DMZ 1500
mtu Training 1500
mtu Future-DMZ 1500
mtu State-Fail 1500
ip address outside 216.x.x.94 255.255.255.240
ip address inside 10.0.0.1 255.255.255.0
ip address DMZ 192.168.0.1 255.255.255.0
ip verify reverse-path interface outside
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 3
pdm logging debugging 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (Corp-DMZ) 1 0.0.0.0 0.0.0.0 0 0
nat (Training) 1 0.0.0.0 0.0.0.0 0 0
static (dmz,outside) 216.x.x.93 192.168.0.100 netmask 255.255.255.255 0 0
static (dmz,outside) 216.x.x.92 192.168.0.5 netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 216.27.224.81 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.0.0.0 255.0.0.0 inside
no floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
sysopt noproxyarp outside
sysopt noproxyarp inside
telnet 10.0.0.0 255.255.0.0 inside
telnet timeout 5
ssh 10.0.0.0 255.0.0.0 inside
ssh timeout 5
console timeout 0
vpdn enable outside
vpdn enable inside
terminal width 80
edmonds_robert Thu, 08/21/2003 - 09:27
I don't see any access-list allowing PCAnywhere traffic.
access-list acl_outside permit tcp host host eq pcanywhere-data
access-list acl_outside permit udp host host eq pcanywhere-status
Unless I'm totally missing something (which I do at times) you'll need those lines. The bad part is, you will have to add those for each PAT translation you have built.
