Can you change Call Transfer with the Bulk Edit tool?
I am involved in migrating subscribers over to CM from a PBX. I've done several hundred so far. Now, I'm told that the "Transfer Incoming Call Field?" should be set to Ring Subscribers Extension, instead of transfer to greeting. How can I change this in the Transfer tab of Bulk Edit? Or can I? I can change this in the subscriber template for new cutovers, but I need to change several hundred subscribers. Thanks.
sarrick
I've always done it on the Tranfer tab - set Enable Transfer to TRUE and click the box stating to use subscribers extension as transfer number.
Thanks. That worked.
