Warning message
TTS conffiguration docs
Aug 22nd, 2003
Will anybody know where to locate the TTS config docs on cisco.com? Moreover, does it require a voicecard for it to properly function?
Cheers,
George.
afuller Sat, 08/23/2003 - 06:40
You don't need a voice card to get TTS working. And there's not much in the way of TTS configuration docs. It just works. For configuring subscribers to be able to use text-to-speech, go here:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/sag/sag402/ex/_saix.htm#1115795
It's the T section in the Index of the Unity 4.0.2 System Amdinistration Guide. As you can see, not a lot goes into enabling your subscribers. Again, it just works.
adam
