Warning message
7507
Aug 24th, 2003
sh in fa4/0
FastEthernet4/0 is up, line protocol is up
Hardware is cyBus FastEthernet Interface, address is 0010.54cf.2080 (bia 0010.
54cf.2080)
, Ground Floor user segment---
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, rely 255/255, load 1/255
Encapsulation ARPA, loopback not set, keepalive set (10 sec)
Half-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 5w4d
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 10000 bits/sec, 9 packets/sec
5 minute output rate 34000 bits/sec, 9 packets/sec
25444955 packets input, 2438571694 bytes, 0 no buffer
Received 5314984 broadcasts, 0 runts, 0 giants, 0 throttles
4033 input errors, 4033 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 watchdog, 791 multicast
26172413 packets output, 3166263320 bytes, 0 underruns
39 output errors, 2810 collisions, 0 interface resets
0 babbles, 0 late collision, 13520 deferred
39 lost carrier, 39 no carrier
0 output buffer failures, 0 output buff
hi all,why multicast is showing 791..pls explain
rais Sun, 08/24/2003 - 08:09
  • Silver, 250 points or more
It simply suggests you have received 791 mutlicast packets.
Thanks.
vmiller Mon, 08/25/2003 - 12:27
  • Gold, 750 points or more
Depending on your routing protocol, and if this interface is an active neighbor in the routing protocol, this could explain multicast packets,
EIGRP and OSPF use multicast
