6500 sup720 pwd mgmt LED status appear orange
victorchen
we have two sup720,one is active another is standby. We found all LEDs in active mode are shown as green, but in standby mode the power management LED is shown as orange. Is that the correct status or not. If it is not correct status,what should I do?
Prashanth Krishnappa
Can you paste the outputs of
sh mod
sh environment
sh environment status
Console> (enable) sh mod
Mod Slot Ports Module-Type Model Sub Status
1 1 48 10/100BaseTX Ethernet WS-X6148-RJ45V yes ok
3 3 16 1000BaseX Ethernet WS-X6516A-GBIC no ok
4 4 16 1000BaseX Ethernet WS-X6516A-GBIC no ok
7 7 2 1000BaseX Supervisor WS-SUP720-BASE yes ok
15 7 1 Multilayer Switch Feature WS-SUP720 no ok
8 8 2 1000BaseX Supervisor WS-SUP720-BASE yes standby
16 8 1 Multilayer Switch Feature WS-SUP720 no standby
Mod Module-Name Serial-Num
1 SAL0721E05R
3 SAL0720DAKS
4 SAL0720DBAL
7 SAD072302ZB
15 SAD072303Y1
8 SAD072301DH
16 SAD072303Y1
Mod MAC-Address(es) Hw Fw Sw
1 00-0d-28-b7-a5-70 to 00-0d-28-b7-a5-9f 1.3 5.4(2) 8.1(1)
3 00-0d-28-48-44-40 to 00-0d-28-48-44-4f 1.0 7.2(1) 8.1(1)
4 00-0d-28-48-06-f0 to 00-0d-28-48-06-ff 1.0 7.2(1) 8.1(1)
7 00-0c-ce-64-0a-d2 to 00-0c-ce-64-0a-d3 2.1 7.7(1) 8.1(1)
00-0c-ce-64-0a-d0 to 00-0c-ce-64-0a-d3
00-07-b3-0e-94-00 to 00-07-b3-0e-94-3f
15 00-07-b3-0e-94-3c to 00-07-b3-0e-94-3d 1.2 12.2(14)SX 12.2(14)SX2
8 00-0c-ce-64-0a-de to 00-0c-ce-64-0a-df 2.1 7.7(1) 8.1(1)
00-0c-ce-64-0a-dc to 00-0c-ce-64-0a-df
16 00-07-b3-0e-94-3c to 00-07-b3-0e-94-3d 1.2 12.2(14)SX 12.2(14)SX2
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw Sub-Sw
1 Inline Power Module WS-F6K-VPWR 2.0 0.0(0)
7 L3 Switching Engine III WS-F6K-PFC3A SAD07220149 1.1
8 L3 Switching Engine III WS-F6K-PFC3A SAD072300PH 1.1
Console> (enable) sh environment
Environmental Status (. = Pass, F = Fail, U = Unknown, N = Not Present)
PS1: . PS2: N PS1 Fan: . PS2 Fan: N
Chassis-Ser-EEPROM: . Fan1: .
Clock(A/B): A Clock A: . Clock B: .
VTT1: . VTT2: . VTT3: .
Console> (enable) sh environment all
Intake Exhaust Device 1 Device 2
Slot Temperature Temperature Temperature Temperature
1 28C(50C,65C) 29C(60C,75C) 27C 28C
3 26C(50C,65C) 37C(65C,80C) N/A N/A
4 27C(50C,65C) 37C(65C,80C) N/A N/A
7 27C(45C,60C) 34C(50C,65C) 34C(60C,75C) 32C(45C,60C)
8 27C(45C,60C) 33C(50C,65C) 33C(60C,75C) 35C(45C,60C)
7 (Switch-Eng) 27C(50C,65C) 41C(50C,65C) N/A N/A
8 (Switch-Eng) 27C(50C,65C) 42C(50C,65C) N/A N/A
7 (MSFC) N/A N/A N/A N/A
8 (MSFC) N/A N/A N/A N/A
Chassis Modules
VTT1: 32C(85C,100C)
VTT2: 55C(85C,100C)
VTT3: 34C(85C,100C)
PS1 Capacity: 3830.40 Watts (91.20 Amps @42V)
PS2 Capacity: none
PS Configuration : PS1 and PS2 in Redundant Configuration.
Total Power Available: 3830.40 Watts (91.20 Amps @42V)
Total Power Available for Line Card Usage: 3764.04 Watts (89.62 Amps @42V)
Total Power Drawn From the System: 1413.30 Watts (33.65 Amps @42V)
Total Power Drawn by the Chassis: 66.36 Watts ( 1.58 Amps @42V)
Total Inline Power Drawn From the System: 0.000 ( 0.000 Amps @42V)
Total Power Reserved as localpool for modules: 14.28 Watts ( 0.34 Amps @42V)
Remaining Power in the System: 2417.10 Watts (57.55 Amps @42V)
Configured Default Inline Power allocation per port: 15.400 Watts (0.36 Amps @42
V)
Fan tray(s) power Requirement/Usage :
Fan Model PowerRequested PowerAllocated
Watts A @42V Watts A @42V
1 WS-C6513-CL 298.20 7.10 298.20 7.10
Slot power Requirement/Usage :
Slot Card Type PowerRequested PowerAllocated CardStatus
1 WS-X6148-RJ45V 100.38 2.39 100.38 2.39 ok
3 WS-X6516A-GBIC 152.04 3.62 152.04 3.62 ok
4 WS-X6516A-GBIC 152.04 3.62 152.04 3.62 ok
7 WS-SUP720-BASE 315.00 7.50 315.00 7.50 ok
8 WS-SUP720-BASE 315.00 7.50 315.00 7.50 standby
Slot Inline Power Requirement/Usage :
Slot CardType Total Allocated Max H/W Supported Max H/W Supported
To Module (Watts) Per Module (Watts) Per Port (Watts)
1 WS-X6148-RJ45V 0.000 399.84 7.000
Chassis per slot cooling capacity : 83 cfm
Fan tray(s) cooling capacity :
Fan Model Ver Cooling Ambient FanStatus
capacity temp
1 WS-C6513-CL 2 1090 cfm - ok
Slot cooling requirement :
Slot CardType Cooling
1 WS-X6148-RJ45V 30 cfm
3 WS-X6516A-GBIC 30 cfm
4 WS-X6516A-GBIC 30 cfm
7 WS-SUP720-BASE 35 cfm
8 WS-SUP720-BASE 30 cfm
Chassis connector rating : 693.00 Watts (16.50 Amps @42V)
Slot connector rating :
Slot CardType ConnectorRating
Watts A @42V
1 WS-X6148-RJ45V 693.00 16.50
3 WS-X6516A-GBIC 693.00 16.50
4 WS-X6516A-GBIC 693.00 16.50
7 WS-SUP720-BASE 693.00 16.50
8 WS-SUP720-BASE 693.00 16.50
Console> (enable)
give me a hand please.... who can answer this question..
It's a bug in CATOS for SUP720. I had the same issue and cisco opened a bug for it.
BugID: CSCec32030
Title: Power Mgmt LED on standby sup720 is amber instead of green
Feature: sup720
Version: 8.1(2)
Integrated:
Severity: 3
State: I
Release Notes:
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCec32030
