ACS stopping auto
Aug 25th, 2003
I have two ACS v3.1, and one of them have been stopped by the system.
The CSMonLog says: "Service CSAuth has been stopped or paused by the system. Monitoring will suspend until the service is restarted.".
Does anyone know what could be happening?
I have started the ACS after that and now everything is working fine.
TIA
drolemc Fri, 08/29/2003 - 06:22
  • Silver, 250 points or more
Are you seeing these messages only during replication? If replication is configured, then replication would probably be the cause of the messages you are getting. I guess you should get the latest Updates or patches for the ACS (http://www.cisco.com/cgi-bin/tablebuild.pl/cs-acs-win).
