Warning message
RME Software Distribution - The Failed job that just won't stop
Aug 25th, 2003
I have a software distribution job that a user created for a single device that failed because of an invalid community string. The job status is listed as "Error". The original job specifications were:
Device reboot option Never
Insert New Boot Commands Yes
Stop on Error No
Backup Running Image No
The problem is that CiscoWorks has been attempting to run the job once a day, every day since the job originally failed. There is no cancel button for this job in the job details report. Removing the job, from job the details report is ineffective - it just reappears the next day. Is there any way to prevent CiscoWorks from running this job again.
amritpatek Mon, 09/01/2003 - 13:15
  • Silver, 250 points or more
You can kill/delete the job by the following procedure. Navigate through "Jobs option" Resource Manager Essentials-> Software Management-> Job Management -> Browse Jobs. Select the Job Status report,and click on the job that has to be removed.
This opens up a new window and then click on the remove tab to remove the job in question.
