Warning message
IDS-MC 1.2 patches say 1.2 is the wrong version
Aug 25th, 2003
The IDS-MC patches for 1.2 say the the MC is the wrong version - do you still want to upgrade.
I know the MC is 1.2 and it also reports 1.2 in the status reports on CiscoWorks.
Does anyone know why I am getting this message please.
scoclayton Tue, 08/26/2003 - 14:24
  • Gold, 750 points or more
Which patch(es) are you trying to load?
scoclayton Wed, 08/27/2003 - 13:15
Thank you for the information. It would appear that you are installing the correct patches. So, I think the warning message can be safely ignored. Go ahead and install them and then go to Server Configuration | About this Server | Applications and Versions and see if the patches were successfully installed.
Scott
