Warning message
why register change?
Aug 25th, 2003
hi, another question, why every time when I config config-register to 0x2102 in my both MSFC3, after power off and power on it will become 0x0?
1. before reboot 6513:
Router>show bootvar
BOOT variable = bootflash:c6msfc3-jk9o3sv-mz.122-14.SX2.bin,1
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
2. after reboot 6513 one or twice
Router>sh bootvar
BOOT variable does not exist
Configuration register is 0x0
amritpatek Mon, 09/01/2003 - 13:30
  • Silver, 250 points or more
Guess, you did not save the configuration after issuing the config-register command. Start the reload after saving the config. Before that, you could go through the following document for more details:
Upgrade Procedure for Systems Running Catalyst OS on the Supervisor Engine and Cisco IOS on the MSFC
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_release_note09186a008019eaeb.html#160129
