Warning message
makchitale Tue, 08/26/2003 - 08:42
  • Silver, 250 points or more
The busy tone is played by the telco switch based on either non availability of resources such as modems or no DS0s available.
what do we see in the 'show modem" output? If this is a PRI "show isdn service" will tell status of DS0s.
Thanks, Mak.
s.kurian Tue, 08/26/2003 - 21:54
i have a 4 e1 /pri link the highest no of users never exceed more than 60. i received a crash dump which showed it was caused due low memory i remeoved perodic accouting by the radius.the access server was working fine for almost 2 yrs.after the problem started i upgraded the bootflash and mica portware tonew ver as it had old ver.
IOS (tm) 5300 Software (C5300-IS-M), Version 12.2(11.8a), MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 16-Jul-02 11:06 by pwade
Image text-base: 0x60008938, data-base: 0x60E72000
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: 5300 Software (C5300-BOOT-M), Version 12.1(20), RELEASE SOFTWARE (fc2)
MOJ-AS5300 uptime is 2 hours, 5 minutes
System returned to ROM by reload at 04:53:12 UTC Wed Aug 27 2003
System image file is "flash:c5300-is-mz.122-11.8a.bin"
cisco AS5300 (R4K) processor (revision A.32) with 65536K/16384K bytes of memory.
Processor board ID 21820776
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 3.1, Item Number 800-2544-03,
Board Revision D0, Serial Number 21820776,
PLD/ISP Version 0.0, Manufacture Date 25-Aug-2000.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
128 Serial network interface(s)
120 terminal line(s)
4 Channelized E1/PRI port(s)
128K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
Boot flash directory:
File Length Name/status
1 1619968 c5300-boot-mz.121-20.bin
2 245877 crashinfo_20030825-114518
regards
shaji
