Is there different between the WIC-1DSU-56K4 and the WIC-1DSU-T1
Aug 26th, 2003
Dear All,
Can anyone tell me is there different between the WIC-1DSU-56K4 and the WIC-1DSU-T1,can the WIC-1DSU-T1 replace the WIC-1DSU-56K4?Thanks very much
bbranch Tue, 08/26/2003 - 23:06
  • Silver, 250 points or more
The primary difference is that the WIC-1DSU-56K4 only supports up to 64K and is designed for 56K DDS operation or 56K/64K DSU/CSU operation whilst the WIC-1DSU-T1 is designed to support fractional T1 or T1 clear channel operation.
If you only need a 56K / 64K circuit you could use either, if you need faster than this then you would need to use the WIC-1DSU-T1
WIC-1DSU-56K4:
http://www.cisco.com/en/US/customer/products/hw/modules/ps3129/products_tech_note09186a00800a99cc.shtml
WIC-1DSU-T1
http://www.cisco.com/en/US/customer/products/hw/modules/ps3129/products_tech_note09186a00800b1501.shtml
