Warning message
can the WIC-1DSU-T1 replace the WIC-1DSU-56K4?
Aug 26th, 2003
Dear All,
Can anyone tell me is there different between the WIC-1DSU-56K4 and the WIC-1DSU-T1,can the WIC-1DSU-T1 replace the WIC-1DSU-56K4?Thanks very much
srehan Tue, 08/26/2003 - 22:50
The 4-wire 56k CSU/DSU implements switched 56k and DDS (leased line ) operation. The hardware feature set is identical to the 4-wire 56/64k CSU/DSU for the 2524-2525.
The 4-wire 56k CSU/DSU is manufactured by Adtran.
* Supports DDS (leased line) operation (AT&T Pub. 62310)
* Supported DDS loop rates 2.4, 4.8, 9.6, 19.2, 38.4, 56, and 64 kbps
* Supports Switched 56 operation at 56 kbps (AT&T Pub. 41458, Sprint TS-0046)
* Receiver sensitivity -45db at all loop rates
* Diagnostic Functions
o Self Test Function (at power on and user initiated)
o Network line and DTE loopbacks User initiated DTE, line, and remote V.54 loopbacks.
* Compliance
o UL 1950
o UL 1459
o CSA 22.2-950
o CSA 22.2-255
o FCC part 15J Class A
o FCC part 68
As compare to WIC-1DSU-T1
The T1 CSU/DSU WAN Interface Card provides full or fractional T1 service. It does not do channelized T1. Look at this link below for more information.
http://www.cisco.com/warp/public/cc/pd/rt/1600/prodlit/t1dsu_ds.htm
wzk007 Wed, 08/27/2003 - 02:02
Dear,
Can you tell me can the WIC-1DSU-T1 replace the WIC-1DSU-56K4 ?Thanks very much
Sincerely
konigl Wed, 08/27/2003 - 07:58
  • Gold, 750 points or more
Yes, it can physically occupy the same slot size (WIC), so it can serve as a replacement in the router. But...
No, you cannot use the WIC-1DSU-56K4 on the same leased line as a WIC-1DSU-T1. You have to replace the leased line circuit too, with one that is compatible with the new WIC.
The T1 leased line circuit uses pins 1, 2, 4, and 5 in an 8-position connector (RJ-45 or RJ-48), when it connects to the DSU/CSU. The 56K leased line uses pins 1, 2, 7, and 8. They don't match up. Signaling on the lines is different, too.
Is this the information you are looking for?
