506 & Public Addresses
First of all, thanks for all responses.
Forgive my limited experience configuring firewalls.
I have a belkin router which is connected to the internet.
WAN IP - 64.x.x.x
Inside IP - 192.x.x.x
Gateway - 64.x.x.x
If i understand correctly, I should replace the Belkin router and configure the 506 with the address information (including NAT/PAT) and I'm ready to go?
I've looked over the document provided by the url and noticed the need for three registered addresses for the small business network configuration. Here's where I'm confused because we have one static public address. The document states;
One outside address - 168.20.1.5
One server address - 168.20.1.6
One internet user address - 168.20.1.7
Help!
Hi -
That document is for example ONLY to show you NAT and PAT config!
My question to you is what kind of setup have you got at the moment, i.e. are you using the Belkin Router for internet connectivity and thinking of placing the 506 between the router and your internal LAN ??
Please explain your full intention of what you propse to do and then I/we can direct you in the right direction (forget that document for the moment).
Thanks - Jay
All apologies..
The win2k server and all desktops are currently pointing to the internal address on the Belkin router as the gateway. I would like to place the pix between the router and the internal lan without having to make changes to all server/desktop gateways (DHCP not implemented). I hope this helps!
Thanks again for responding!
Hi -
OK, now that's clear, following is a sample config for a PIX 515 running 6.2(2) - what version have you got on the PIX, do command 'show version' and it will show the current version and IOS.
But this config would be okay to go with - just change the required IP addresses etc.
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password encrypted
passwd encrypted
hostname pixfirewall
domain-name test.dom
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
no logging on
interface ethernet0 100full
interface ethernet1 100full
mtu outside 1500
mtu inside 1500
ip address outside 192.168.1.10.1 255.255.255.224
ip address inside 10.10.10.1 255.255.0.0
ip audit info action alarm
ip audit attack action alarm
no failover
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 192.168.1.10.3 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00
sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
terminal width 80
Thanks - Jay
Hi -
Firstly, NO question is DUMB!! - What you need here is a 'route command' here is a explanation;
route command:
When passing data to a destination network that is not directly connected to the PIX, the destination network must be specified. The destination network is specified using the route command. The PIX is not a router, although it sometimes behaves in a routerlike fashion. The PIX cannot make the same kinds of dynamic routing decisions that a router makes; it must be configured statically.
Route if_name ip_address netmask gateway_ip [metric]
Here, if_name is the name of the interface that the data will pass through when exiting the PIX. The gateway_ip is the IP address of the device (usually a router) that is the next-hop device to the destination network.
It is common to use a default route to the untrusted side of the PIX (the outside interface). The following is an example of how the route commands might be configured if the outside interface were connected to the Internet and the inside interface were connected to your company intranet, which consists of three subnets. The inside interface is directly connected to the 10.2.0.0 255.255.0.0 subnet. The 10.3.0.0 and 10.4.0.0 subnets are reached via a router with a local interface of 10.2.1.4.
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
route inside 10.3.0.0 255.255.0.0 10.2.1.4 1
route inside 10.4.0.0 255.255.0.0 10.2.1.4 1
With the default route, any traffic that is permitted to pass through the PIX that has a destination network other than 10.2.0.0, 10.3.0.0, and 10.4.0.0 will be passed through the outside interface to 192.168.1.1 for routing.
**In your case the 10.2.1.4 would be your switch IP address, the '1' at the end states that it is 1 metric away (or 1 hop)**
Hope this explains it - Jay
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
OK. .
Just to verify everything is in order.
The belkin router info is;
WAN IP - x.x.42.46
LAN IP - x.x.1.100
Subnet - 255.255.255.224
Gateway - x.x.42.33
I will connect the the pix ouside port to the belkin lan port. here's current running config on the pix;
PIX Version 6.3(1)
interface ethernet0 auto shutdown
interface ethernet1 auto shutdown
enable password eophEPJ3DEofiYBk encrypted
passwd xxxxxxxxxxxx encrypted
hostname PIX
fixup protocol sip udp 5060
names
pager lines 24
mtu outside 1500
tu inside 1500
ip address outside x.x.1.200 255.255.255.224
pdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 x.x.1.200 1
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Could you please verify before I install?
Thank you for all your patience. I really appreciate all the help you have provided.
P.S. I am trying to convince my manager to supply Cisco training. As you have noticed I really need it!!!
