Warning message
Installing WIC-1ENET on a 1750 router
Aug 28th, 2003
Hi.
I'm installing a WIC-1ENET on a 1750 router that seems to follow all the Cisco guidelines and still get the following:"00:00:08: %PQUICC-1-UNKNOWN_WIC: PQUICC(0), WIC card has an unknown ID of 0x39"
The card is installed on port 1 which is OK with our IOS version.
I did not find what I have to do in order to get this card to work.
Amir
bbranch Thu, 08/28/2003 - 23:13
  • Silver, 250 points or more
What IOS do you have loaded, you need a minumun of 12.1(5)YB, 12.2(2)XH, 12.2(2)XJ, 12.2(2)XK, 12.2(2)XQ, 12.2(4)T, 12.2(8)T, 12.2(8)YJ, 12.2(8)YL, 12.2(8)YM, 12.2(8)YN, 12.2(11)T, 12.2(11)YU, 12.2(11)YV, 12.2(13)T, 12.3(1) to support the WIC-1ENT in a 1750
amir_prat Fri, 08/29/2003 - 09:09
We have 12.2(17)on a cisco 1750 (MPC860) processor (revision 0x601) with 36864K/12288K bytes of memor
y.
Do I have to get an IOS upgrade before the Card would work?
Amir
