Unable to break dialtone on analog E+M tie-lines
Aug 29th, 2003
I have four E+M connection tie-line 4-wire immediate signalling circuits. I can seize the tie-lines from direct trunk select and receive dial-tone from the router ports but, i cannot break local dialtone.
debugging shows the transition from onhook to offhook but - i do not see any digits being played out to the router... Which probably explains the dial tone issue. I know the PBX trunks are good.
Also - how do i remove secondary dial-tone?
thusain Mon, 09/01/2003 - 15:03
  • Silver, 250 points or more
If no digits are being recieved by the router, then the dialtone wont be broken.
You can use connection plar under the voice port and send the call to a destination as soon as the port is siezed. This will eliminate the second dial tone.
Taimoor
tredgrove Tue, 09/02/2003 - 07:35
Taimoor,
Thanks for reply.
The E&M lines are local PBX to remote PBX tie-line trunks. Router A has extension groups 2... and 3...
Router B has extensions in the range 83..
Does the connection PLAR allow for flexible dialling from PBX-A subscribers to PBX-B subscribers and vice-versa ?
tredgrove Tue, 09/09/2003 - 08:21
Taimoor.
OK with you on the PLAR option. All squared away there. Problem persistant, BUT found a fix
FYI
ran debug on vtsp dsp all and vpm all - all ok one side far end choked with error
traceback and error message. *Mar 1 08:55:48.251: %DSM-3-INTERNAL: Internal Error : No DSM handle provided-Traceback= 619EE3F8 61568BF4 6156004C 615648D0 61564EB8 61566B80 61568974
running 12.2.(15)T far end and 12.3 2T near end
Seems i need a patch of IOS.to 12.2(16.1)T or greater to resolve.
Thanks for the nudge. Hope this is useful to others.
