Warning message
CAT-6506: BOOTFLASH Directory shows 0 files inside
Aug 31st, 2003
First of all thanking all of u that spent time in going thru my issues.
Here is the story:
I knew that one of my CAT-6506 ( Cat OS 6.3(5) ) here is been converted out from Native to Hybrid Long back. When I enter dir bootflash from Sup Mode, it shows that “no files on bootflash:”, though "show boot " ( bootvar) shows that last reboot took the “first image” image from directory directory "bootflash" ( sup-bootflash) . Pelase see below.
In_Qed_Cont_6506_02> show boot
BOOT variable = bootflash:,1;
CONFIG_FILE variable = slot0:switch.cfg
Configuration register is 0x10f
ignore-config: disabled
auto-config: non-recurring, overwrite, sync disabled
console baud: 9600
boot: image specified by the boot system commands
In_Qed_Cont_6506_02> dir bootflash:
No files on device
31981568 bytes available (0 bytes used)
Now my question here is
01. “ Am I going to be in trouble if I reboot this switch by any chance ?
02. Why didn’t I seen the Cat6000*.sup2.xxx file on sup-bootflash: ?
03. Do you think that file system format on Flash card is still on Native Mode (not CAT OS format )hence it is unable to see it ?
04. What do u advice in this scenario. ? I have already opened a TAC case while my
TAC engineer didn’t given me a proper answer
05. If item#3 is TRUE, Can I format my sup-bootflash ? I hope this doesn’t impact on its switching/mls/l2 process unless it gets powerdown in between .
Looks to have your Immediate help. Once again thanks for bearing me …
In_Qed_Cont_6506_02> show module
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP2-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
2 2 8 1000BaseX Ethernet WS-X6408A-GBIC no ok
3 3 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
Mod Module-Name Serial-Num
1 SAL06386BAM
15 SAL06375WL2
2 SAL06261Y2L
3 SAL06334R6L
Mod MAC-Address(es) Hw Fw Sw
1 00-06-d6-5b-d8-aa to 00-06-d6-5b-d8-ab 3.10 7.1(1) 6.3(5)
00-06-d6-5b-d8-a8 to 00-06-d6-5b-d8-a9
00-0b-45-22-1f-80 to 00-0b-45-22-23-7f
15 00-09-12-38-23-80 to 00-09-12-38-23-bf 2.5 12.1(8b)E1 12.1(8b)E11
2 00-09-12-7b-03-f8 to 00-09-12-7b-03-ff 2.1 5.4(2) 6.3(5)
3 00-0a-b7-53-22-68 to 00-0a-b7-53-22-97 6.1 5.4(2) 6.3(5)
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw
1 L3 Switching Engine II WS-F6K-PFC2 SAL063764B7 3.3
In_Qed_Cont_6506_02> show ver
WS-C6506 Software, Version NmpSW: 6.3(5)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Feb 7 2002, 19:33:49
System Bootstrap Version: 7.1(1)
Hardware Version: 3.0 Model: WS-C6506 Serial #: TBM06403951
PS1 Module: WS-CAC-1300W Serial #: SNI06290203
PS2 Module: WS-CAC-1300W Serial #: SNI06290197
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL06386BAM Hw : 3.10
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 6.3(5)
Sw1: 6.3(5)
WS-F6K-PFC2 SAL063764B7 Hw : 3.3
2 8 WS-X6408A-GBIC SAL06261Y2L Hw : 2.1
Fw : 5.4(2)
Sw : 6.3(5)
3 48 WS-X6348-RJ-45 SAL06334R6L Hw : 6.1
Fw : 5.4(2)
Sw : 6.3(5)
15 1 WS-F6K-MSFC2 SAL06375WL2 Hw : 2.5
Fw : 12.1(8b)E11
Sw : 12.1(8b)E11
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 130944K 62392K 68552K 32768K 1537K 31231K 512K 335K 177K
Uptime is 278 days, 4 hours, 24 minutes
