Warning message
Passive Interface command usage
Answered Question
Aug 31st, 2003
We have a HSSI frame Relay interface with about 50 subinterfaces on it. We're running OSPF on all of them but have the need to run RIPv2 on a single new PVC.
How can I setup RIP to run on the specific sub interface without having to use the passive interface command on all the other subinterfaces ?
I'd also like to to stop OSPF routing updates on this interface also but am not sure if this is possible.
thanks
Correct Answer by ruwhite about 13 years 11 months ago
Simply cover all the interfaces under OSPF, as you normally would, and then passive that one interface out. For RIP, it's not so easy, since there's no wildcard bits under RIP. You can use the passive interface default command, as the first reply noted, under RIP, to resolve this.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a008008784e.html
2651A#sho run | b rip
router rip
passive-interface default
no passive-interface FastEthernet0/0
Russ.W
Correct Answer by bbranch about 13 years 11 months ago
You can use the "passive interface default" command to make all interfces passive, then enable RIP on the individual interfaces that require it:
router rip
no passive-interface s0/0.1
also if you make the OSPF network statements specific for an interface then you can control which interfaces you enable it on:
router ospf 1
network 10.1.1.1 0.0.0.0 area 0.0.0.0
Overall Rating: 5 (2 ratings)
Correct Answer
bbranch Mon, 09/01/2003 - 01:35
  • Silver, 250 points or more
router rip
router ospf 1
Correct Answer
ruwhite Mon, 09/01/2003 - 05:51
  • Gold, 750 points or more
router rip
Russ.W
