Warning message
Port utilization
Sep 2nd, 2003
Hello All,
Is their any way to check the port utilization for wan link.
My 6500 switch is connected to 7200 router.
Any tool to check the traffic flow between the router port and switch port.
regards,
shashank
sholom Wed, 09/03/2003 - 12:44
MRTG is a great free tool for graphing traffic on cisco routers and switches.
Check out http://mrtg.hdl.com/mrtg.html
you can also run "show top" command on the 6500 for a quick snapshot of utilitzation. And look at the interface on the router to see its load.
Hope this helps.
