vpn3000 and a sonicwall firewall
whanson
Level 2
Level 2
Has anyone successfully connected a vpn3000 and a sonicwall firewall lan-to-lan. I'm on the VPN3000 side and am receiving error messages indicating that I'm receiving unencrypted packets from the sonicwall.
jurrien
Yes, I've got L2L between a Sonicwall PRO200 and VPN3030 running without any problems. I've used a document of SonicWall to configure the VPN3030 and the Sonicwall. Importent is to have your Sonicwall and VPN3030 updated to the lastest firmware.
You can find the documentation on the Sonicwall support site.
At the moment the VPN3030 is running 3.6.7 and the Sonicwall 6.4.2.0.
Getting a L2L tunnel running between the VPN3030 and a Sonicwall SOHO/3 behind a NAT'ted Internet solution never succeeded because of NAT traversal issues.
Best regards,
Jurrien Wijlhuizen
