VPN - Split Tunnel
Answered Question
Sep 2nd, 2003
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
Can anyone please help me as my VPN access works fine without Split Tunnel. But when I put the Split Tunnel it stops working.. here is the configuration.. my PIX is behind a Checkpoint F/W and NAT is working on CheckPoint so thats why I donot wana configure NAT on PIX.. I would really applicate you help.. thanks in advance :-)
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security10
nameif ethernet3 intf3 security15
nameif ethernet4 intf4 security20
nameif ethernet5 intf5 security25
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 101 permit ip any any
access-list 120 permit tcp 10.200.125.0 255.255.255.0 host 10.200.124.1 eq www
access-list 120 permit tcp 10.200.119.0 255.255.255.0 host 10.200.124.1 eq www
access-list 152 permit ip 10.200.124.0 255.255.255.0 10.200.125.0 255.255.255.0
access-list 152 permit ip 10.200.125.0 255.255.255.0 10.200.124.0 255.255.255.0
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
interface ethernet3 auto shutdown
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
mtu outside 1500
mtu inside 1500
mtu intf2 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
ip address outside 10.200.123.253 255.255.255.0
ip address inside 10.200.124.254 255.255.255.0
ip address intf2 127.0.0.1 255.255.255.255
ip address intf3 127.0.0.1 255.255.255.255
ip address intf4 127.0.0.1 255.255.255.255
ip address intf5 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 10.200.125.1-10.200.125.254
pdm history enable
arp timeout 14400
nat (inside) 0 access-list 101
access-group 120 in interface outside
route outside 0.0.0.0 0.0.0.0 10.200.123.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server AuthInbound protocol radius
aaa-server AuthInbound (inside) host 10.200.124.1 xxxxxxxxxxxxx timeout 10
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap client authentication AuthInbound
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp client configuration address-pool local ippool outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup test address-pool ippool
vpngroup test split-tunnel 152
vpngroup test idle-time 1800
vpngroup test password xxxxxxxxxxxxxxxxxxxx
vpngroup group idle-time 1800
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Correct Answer by chris.evans@exp... about 13 years 10 months ago
for this ACL
change it to
access-list 152 permit ip 10.200.124.0 255.255.254.0 any
the split-tunnel command uses the "source" portion of the ACL to know what networks are internal to the pix.. then everything else, the client will know to split tunnel..
Chris
Overall Rating: 3 (1 ratings)
Correct Answer
chris.evans@exp... Fri, 09/05/2003 - 19:30
for this ACL
change it to
Chris
