Warning message
question with callmanager installation on other hardware
Sep 2nd, 2003
when i completed the cmm 3.1(4b) installation,found the callmanager services not working,
here's the log form event viewer:
Event Type: Error
Event Source: Service Control Manager
Event Category: None
Event ID: 7031
Date: 9/2/2003
Time: 1:39:23 PM
User: N/A
Computer: HNEP-32E6FA7F61
Description:
The Cisco CallManager service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 60000 milliseconds: Restart the service.
anybody any suggestion?
thanks
irisrios Mon, 09/08/2003 - 10:58
  • Silver, 250 points or more
Is it an upgrade or a fresh installation? If it is an upgrade then the error can occur if something goes wrong during installation or it gets installed with errors. In this case, you might need to un-install and then re-boot and then re-install the CCM again. If it is a fresh installation, then I wonder what might have gone wrong.
