Warning message
Configuring PIX 501
Sep 3rd, 2003
Our ISP has supplied us a Cisco router which is currently connected to a switch. I am trying to add a PIX 501 into the mix. Below is my current running configuration on the PIX and the router. I am not able get an outside connection when the PIX is in place. What am I missing? Right now I just want to access the internet with the PIX in place. When I get that figured out I want to disable the nat on the router and take care of it on the firewall.
Thanks for your help.
PIX Configuration
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
clock timezone CST -6
clock summer-time CDT recurring
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 70.141.173.66 255.255.255.248
ip address inside 192.168.1.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
arp timeout 14400
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
Router Configuration
ip name-server 70.140.240.35
ip name-server 70.140.240.36
interface Serial0
ip address 70.141.103.140 255.255.255.252
no ip directed-broadcast
ip nat outside
encapsulation ppp
no fair-queue
service-module t1 timeslots 13-24
interface FastEthernet0
ip address 192.168.1.1 255.255.255.0 secondary
ip address 70.141.173.64 255.255.255.248
ip nat inside
ip nat inside source list 1 interface Serial0 overload
ip nat inside source static tcp 63.141.173.65 25 192.168.1.7 25 extendable
ip nat inside source static tcp 63.141.173.65 110 192.168.1.7 110 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 70.141.103.139
From the pix, can you ping 70.141.174.64?
Problems:
1. You do not have a default route statement on the pix
route outside 0.0.0.0 0.0.0.0 70.141.173.64
2. The router is doing nat. From the pix, can you ping 70.141.174.64 (the ethernet interface of the IOS router)?
To tell what exactly is being natted, you would need to do a
sh ip access-l
on the IOS router, and look for access list 1. Depending on how the acl is written, it may not be necessary to do the following to disable nat.
On the router:
enable
int f0
no ip nat inside
int ser0
no ip nat outside
should disable nat on it.
jerryfreeman Thu, 09/04/2003 - 06:29
I added the line
to my config and I can ping that address from the PIX, but I still cannot reach the internet. I also tried to ping 70.141.103.140 from the PIX and I get no response. Is there something in the router config that is keeping the firewall from accessing the internet?
jerryfreeman Fri, 09/05/2003 - 09:44
PIX Configuration
names
pager lines 24
mtu outside 1500
mtu inside 1500
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
interface Serial0
ip nat outside
encapsulation ppp
no fair-queue
ip nat inside
ip classless
mmeditz Sun, 09/07/2003 - 01:35
Hi Jerry,
What is in access-list 1? You telling the nat process to translate the traffic matching ACL 1 and that should at least include the outside IP of your PIX (70.141.173.66). To just test this out don't be specific at first, just permit IP any in ACL 1 and test for connectivity from the PIX.
Good Luck.
Mike
