Warning message
Configuring custom AV Attribute pairs in CSACS
Sep 3rd, 2003
Hello
I'm running CSACS to authenticate users to a Colubris CN3500 Access Controller and Colubris provides a 'custom av pair' to specify traffic quotas for users. How would I create these pairs within csacs? Thanks
jasonhumes Tue, 09/09/2003 - 11:52
Hello
First off, thanks for the document, it did help out very much. I've created my custom avpair.ini file which looks like this:
[User Defined Vendor]
Name=Colubris
IETF Code=8744
VSA 1=colubris-max-input-packets
VSA 2=colubris-max-output-packets
VSA 3=colubris-max-input-octets
VSA 4=colubris-max-output-octets
[colubris-max-input-packets]
Type=INTEGER
Profile=MULTI IN OUT
Enums=MaxPacket
[colubris-max-output-packets]
Type=INTEGER
Enums=MaxPacket
[colubris-max-input-octets]
Type=INTEGER
Enums=MaxOctet
[colubris-max-output-octets]
Type=INTEGER
Enums=MaxOctet
[MaxPacket]
0=10
1=100
2=1000
3=5000
4=10000
[MaxOctet]
0=100000
1=1000000
2=10000000
3=100000000
4=200000000
5=500000000
And I've imported it using CSUtil and got no errors. But I cant seem to get it to show up in the ACS Admin pages....I've looked under user/group, interface and I cant find it anywhere...please help. Thanks
Jason Humes
gfullage Tue, 09/09/2003 - 17:41
  • Cisco Employee,
You have to add a NAS and say that it's a type "Colubris". Then it'll appear under Interface Config, and you'll be able to enable parameters for the User and/or Group.
jasonhumes Wed, 09/17/2003 - 07:16
Hello
OK Great, I've gotten the 4 Individual items to appear within CSACS under the group config, yet the possible values I've configured dont seem to show up, just a box with a 0 in it next to each item. Any ideas. Thanks again.
gfullage Wed, 09/17/2003 - 20:39
  • Cisco Employee,
This is because you have "MULTI" defined in the VSA. This says that you can send back more than one value for this attribute, so the box in the GUI becomes a box that allows you to add more than one value. If you remove MULTI and just have it as "IN OUT" then the boxes will be displayed as a drop-down allowing you to select one of the values you specified.
