Warning message
1750 Router, interface has a very high utilization
Sep 4th, 2003
The is a 1750 router with 2 serial interface, but the traffic flows maximum to one interface only and the other one is rarely used.The is no multi link or any switching or any routing which specifies to use only one interface.
frank0815 Thu, 09/04/2003 - 00:54
ok,
go on this interface, which you will not use.
And shutdown this interface. use:
"conf t"
int ser xxx
sh = shutdown (the interface goes down now)
leaf this interface with 2 times "exit"
"wr"
then
"sh ip int brief"
that`s all
now is one seriell interface down.
sachinraja Thu, 09/04/2003 - 06:49
  • Red, 2250 points or more
Try doing a per-packet load-balancing on the 2 interfaces. enable "ip load-sharing per-packet" on the interfaces and ip cef globally.
The load variations may be due to the fact that the interfaces do per-destination load balancing, which is session based and not packet based.
Cheers !
