Network connectivity
Sep 6th, 2003
I have a router that gives me exit to the Internet and since about 4 days ago when I ran the command
" sh proces " it's showing 59 % to 65 % when the norm has been 3% to 10 %.
So there is a device or several of them that are causing too much traffic due to an electronic problem or a virus or excessive use by the user. I want to know:
1. - What can I do to identify the IP or the MAC address of the device(s) that are causing this traffic?
2. - There is any kind of access-list or debug mechanism that help to identify this devices?
3. - There is an any kind of software, even if different from Cisco product tat can help me to troubleshoot this problem?
4.- By tha way, there is any way to stop or control viruses coming into the system from the router?
Thanks for any help I can have from you all
jprada Mon, 09/08/2003 - 22:02
Jay
Thanks, I am looking into the links.
J.P
Anonymous (not verified) Tue, 09/09/2003 - 00:09
do a ip accounting on the ethernet inetrefaces and look for 92 bytes and 48 bytes packets. Lots of them comming from same hosts. If this is the case you have a virus on the source ip addresses.
To block the 92 bytes you only need an ext accesslist
deny icmp any any echo
deny icmp any any echo-reply
for the 48 bytes I'm not sure but Cisco has generated a common accesslist for these viruses search the web. The problem with thius one it thends to block alot of other traffic as well.
good luck
jprada Mon, 09/15/2003 - 00:19
Thanks for your response. This is the access-list created and it is in effect:
Access-list 120 Applied to Fast Ethernet0/0 to watch incoming traffic
Deny tcp any any eq 135 log
Deny udp any any eq 135 log
Deny tcp any any eq 137 log
Deny udp any any eq netbios-ns
Deny tcp any any eq 138 log
Deny udp any any eq netbios-dgm
Deny tcp any any eq 139 log
Deny udp any any eq netbios-ss
Deny tcp any any eq 445
Deny tcp any any eq 4444
Deny icmp any any echo
Deny icmp any any echo-reply
Permit ip any any
So far it is producing some ip numbers and we are on it.
