Warning message
routing protocols in pix ios 6.3(3)
Answered Question
Sep 8th, 2003
does 6.3(3) support RIP also apart from ospf , if not how come one of the caveats is that RIPv2 mcast updates are sent across an interface that has no rip enabled on it.
Correct Answer by scoclayton about 13 years 11 months ago
PIX 6.3 code supports both RIP (v1 and v2) and OSPF. The caveat is that you cannot configure both RIP and OSPF on the same PIX. You must choose which one you want to use. Hope this helps.
Scott
Overall Rating: 3 (1 ratings)
Correct Answer
scoclayton Mon, 09/08/2003 - 07:14
  • Gold, 750 points or more
Scott
